Can any1 help me to find the solution for this:
I have a form in which there is a report menuitem button and when I press this button to open report then what i want report should contain data regarding only selected record in form.
Ankit…!
Jyothi
April 4, 2012, 10:00am
2
Hi Jyothi,
Thanks for reply…!
I follow same steps, but sitll it is not working…!
do i need to write some more methods, in report or form.
Jyothi
April 4, 2012, 11:00am
4
Hi Ankit_M ,
In u hav to assigned ur table like this right
tableObj = element.args().record();
After that u have to send ur database in fetch method like
select datasourcetablename (Copy as it is from ur report datasource node) where datasourcetablename .Primaryfield == tableObj .PrimaryField;
element.send(datasourcetablename);
Jyothi
April 4, 2012, 11:03am
5
Hi Ankit_M ,
U hav assigned ur form’s table like this right
Hi Jyothi,
Thanks, I know you are tring so hard to explain me, but still I am so far…
Can you please explain me step by step from starting…
will be thankfull…!
All methods are present in the Override Methods of the Report!!
public class ReportRun extends ObjectRun
Common cur; //Common is the name of table
public boolean fetch()
QueryBuildDataSource qbs;
QueryRun qr;
qr = new QueryRun(element);
cur = element.args().record();
element.send(cur);
return true;
karlaa
April 5, 2012, 12:23pm
8
hi guys, i am a newer here and hope to have a good time in the near future… karla
collateral loans
Kanagu
April 6, 2012, 6:00am
9
Hi to all,
I am also have a same doubt in SSRS Report.
Please help me.
Thanks in Advance
