Hello,
i want to open a pdf file in AX (Axapta 4). My first intension was something like the code below, but this is not realy a good way (because of the fix path…).
I tried below code and the .pdf file seems to open from EP in AX 2012 R2.
I created a new web control and added the web url menu item to the approval node. Hence on click of the approval records from Role center pages my web page gets called. Below is the code snippet to be written under page load:
Adoebe program will open pdf file for you. and there are many other .net imaging application has the same function to process and edit pdf document in an easy way. best luck
