I’m using Nav 2009 R2. now I want to open the excel 2010 file which we save in Nav server . example : \Navappsvr\Document\ABC.xlsx . I create new FORM in Nav and also create push button to execute the excel file.
write CAL/CODE : ON PUSH
HYPERLINK (’ \Navappsvr\Document\ABC.xlsx ') ;
but I have the Error : C/SIDE hyperlinking failed.
You tried to hyperlink to this target:
\serverpath\share\doc.ext
Do you want to place that hyperlink target on the clipboard?
I used it from the Classic . actually we make some macro file excel which read from the nav SQL Database. and we want all the query excel run from NAVision.
that way I make new FORM in NAv , and make some common button , and make link to share folder in NAV Server.
it work fine if create hyperlink to excel 2007 . Hyperlink (’\Navapsvr\document\abc.xls’);
but if I want to run excel 2010 : Hyperlink (’\Navappsvr\document\abc.xlsx’); I got error : C/Side Hyperlink Failed …
is there other way to run excel 2010 file from Share folder server ?..
Ok, but did you test it manually from the server from Windows explorer (not NAV)?
If it fails with the Excel 2010 file but works with the Excel 2007 file (which of course both exists in the document folder), then it’s more that the Excel 2010 application is not installed correctly, so that the extension is not known.
