Open editable page from Detailed page in EP in Ax 2012.
In Enterprise Portal, when i double click on selected record in my List page , it opens detailed page view in non-editable mode.
In detailed page, i have added Action page and when clcik on Edit button, it opens detailed page in Editable mode.
But the problem i am facing here is, editable record information is not related to my record. It is showing first record from the data set.
I have specified DataSourceId, DataMember as PrimaryTable_Current and DataKeyNames properties for axForm control in Deta****ilsPageEdit user control… but i didn’t get related record in edit mode.
How to open related record in editable mode… when else i have to set to achieve this.
Please help me.
HI
To take more time Lispage load in Enterprise portal.
so please make sure that page loaded or it’s running.
I hope that it’ll solve the solution . don’t forget to make verified solution
Regards
Syed Abuthahir
Hi Syed,
Thanks for the replay.
I am sorry, I could not understand your suggestion, how it is related to my issue.
Can you please explain collaboratively if possible.
The issue seems to be a problem in the data source and joins in the details page.
You please verify the page’s all the data sources are joined properly.
If you put inner join instead of the outer or data not available in the joined table only active record will come.
K.S. Mohamed Riswan
