Hi Does anybody know if it’s posible to use the Onlookup trigger on the table for a field defined as FlowFilter? Ole
I would try it. Program a lookup, see if it works.
Sure it should work fine. If I remember rightly though, I think you can’t use the OnValidate trigger. But as Emiel says, quickest solution is to try it.
