Hello People,
I’ve posted my Problem in another thread, but then I’ve read, that anybody should open an own Topic for own problems so I post it again.
I hope anybody can help me.
i have a problme with MS Dyn NAV OnlineHelp too, but it is a bit heavier. But at first I have to say, please forgive me my maybe bad grammar, i am a Non-Native-English-Speaker and I am from germany Hello World
At first I’ve read the posts of Luc van Vugt here, and i was very impressed, and he seems to be the one who could be able to help me.
In case you are reading this, pls let get a piece of your knowledge.
To determine my problems:
I am an apprentice in Company which provides a MS Dyn NAV Solution. Know we have to certify our Solution for the RoleTailoredClient.
Since about 4 Weeks day to day I do nothing else except trying to create an OnlineHelp. I’ve tried Robohelp and MS Helpbuilder 2009 sp1, no success.
(with our version of robohelp it was possible to create a help for the classic client, but it was just a testversion of RH, because the aktivation Server of this old version are not longer availeble, Adobe provided a solution to solve this problem but even this doesn’t work )
Know I’d like to get a list of things I need, to create a working Helpfile für the RTC. It should be field-sensitive.
I’ve tried to take our hmt-files, they are filled with helpstexts like “this is a field where you can insert a date”(just for testing).
I have HTMLWorkshop. I have the Report from MS which can create HelpTopics and TOC, all this I used. I have tested our helpfiles with testdata and the empty files from the report, no success.
Thats the main problem. I’m able to refine it a bit, during using HTMLWorkshop, there are Options to fill the Index automatically, but this doesn’t work. The TOC from the report can be loaded in the Project, the hmt-files too, but there are no index, then i’ve read a documentation, with the notice, that if i check the “autoinsert index by keywords”-option, i have to compile the helpfile with htmlworkshop and then it would be create and filled automatically. But thats wrong, i only have empty index file with “tags tags tags
I guess thats the problem why the help doesn’t work when it is compiled.
Have you Luc or anyone else maybe an example of a selfcreated index,toc and htm helpfile? So i cna compare to our created files, some of them are created by self developed reports, which create the testdate like "this is a date field … ". Maybe the htmfiles are wrong.
When i’m going to compile the file I use the config.defaul.xml and the config.RBC.xml(RollenBasierterClient => RoleTailoredClient). Additive I use the Shared folder, which is found in the installationfolder of NAV Help Builder. C:…\Sample\Shared… .
hmm to compile i use the hhc.exe from htmlworkshop.
If you need any other information to help me to solve my problem, i will give you all information you need, but i am at the end of my knowledge, and need help to create the help
friendly regards
NonHelpExpert
