Hello;
i want to know if there is a possibility to add diemsions(department,CostCentre,Purpose)in this method: onHandQty??
Hello;
thank you in advance.
Everything is possible, but how should it work? It’s doesn’t sound like a well-thought-out idea… unless you tell us more.
Definitely if you want to add additional storage dimensions, it will be much more work than adjusting onHandQty().
Hello;
thank you Martin Drab for you help,I am so sorry,i didn’t explain it very well and im a beginner in axapta.
So, there is a class that export Data from dynamics ax to excel document,in this class i find the method OnhandQty() the code is:
void onHandQty(InventSum _inventSum, InventDim _inventDim)
InventTable inventTable = _inventSum.inventTable();
InventDimGroupId inventDimGroupId = inventTable.DimGroupId;
fieldId x,y;
InventDim tmpInventDim;
InventDimParm tmpInventDimParm;
InventQty onHandQty;
str line;
InventTableModule inventTableModule = inventTable.inventTableModuleInvent();
if (!_inventSum.InventDimId)
_inventSum.InventDimId = InventDim::findOrCreate(_inventDim).inventDimId;
onHandQty = InventSumDatePhysicalDim::onHandQty(countDate, _inventSum.ItemId, _inventDim, inventDimParm);
if (OnHandQty)
line = _inventSum.ItemId + ‘;’;
line += _inventSum.itemName() + ‘;’;
if (inventDimParm.ConfigIdFlag)
line += _inventDim.ConfigId + ‘;’;
if (inventDimParm.InventSizeIdFlag)
line += _inventDim.InventSizeId + ‘;’;
if (inventDimParm.InventColorIdFlag)
line += _inventDim.InventColorId + ‘;’;
line += _inventDim.InventSiteId + ‘;’;
line += _inventDim.InventLocationId + ‘;’;
line += InventLocation::find(_inventDim.InventLocationId).Name + ‘;’;
line += tmpInventDim.wMSLocationId + ‘;’;
if (inventDimParm.InventBatchIdFlag)
line += _inventDim.InventBatchId + ‘;’;
if (inventDimParm.WMSPalletIdFlag)
line += _inventDim.WMSPalletId + ‘;’;
if (inventDimParm.InventSerialIdFlag)
line += _inventDim.InventSerialId + ‘;’;
line += num2str(onHandQty, 0, 2, 0, 0) + ‘;’;
line += num2str(inventTableModule.Price(), 0, 4, 0, 0) + ‘;’;
line += num2str(inventTableModule.priceUnit(), 0, 0, 0, 0) + ‘;’;
line += num2str((inventTableModule.Price() / inventTableModule.PriceUnit()) * onHandQty, 0, 2, 0, 0);
csvIO.write(line);
the exported document in excel contain these columns:
My problem is to add storage dimensions( department,CostCentre,Purpose) related to item number, in the exported excel document,i tried hard to add the code: line = inventTable.Dimension + ‘;’; in the method onHandQty but in vain.
I hope that i explain this well and please help me to resolve this problem.
pleease can someone help me.
You have to access ledger dimension fields one by one. For example:
inventTable.Dimension(Dimensions::code2ArrayIdx(SysDimension::Center));
