There is a form with the two fields which is of type enum of same datasource.One enum is in the grid with the records of other fields and another is in the above that grid.So when we are checking the checkbox field which is above the grid will select all the records in that form by ticking another check box which is in the grid.But when we are selecting the check box field in the grid then the check box above the grid is also getting selected.Can you tell how to resolve this.
