OnAfterGetCurrRepord
Hello together,
I would like to suggest to get the “OnAfterGetCurrRecord” trigger back into RTC.
We have the need to display some information about the active line at an external device (Customer Display).
The issue is that the “OnAfterGetRecord” just runs through all records (which is good) but we do not know which the current record is.
It would be of great help to either get the trigger back, or on the other side to get the OnAfterGetRecord trigger fired last for the current record (that is trigger all other records first and the current record last) or even better get a bool parameter into the “OnAfterGetRecord” trigger telling if the record calculated is the current record.
