OLE control or automation server
Please acn you remind in what is the name of this .ocx i have to install to solve this message . and where it’s found ? I am having this message when trying to export or update the excel sheet from Analysis reports . could not create an instance of the OLE control or Automation serve r identified by GUID = {F9043C85-F6F2-101A-A3C9-080028F49FB} check the OLE control or automation server is correctly installed and registerd thank you
{F9043C85-F6F2-101A-A3C9-08002B2F49FB} belongs to “Microsoft Common Dialog Control, version 6.0”
and resides (at least on my Vista) under:
C:\Windows\system32\comdlg32.ocx
Your’s is “slightly” different but I guess it is also somewhere around that.
Try to compile all your NAV objects and not the ones which do not compile.
Post a list here.
