OLE Control or Automation server returned error(HRESULT)
hi all,
anyone ever faced this error message?
“this message is for C/AL Programmers:
an exception was raised in method name. the OLE Control or Automation server returned error(HRESULT) -2147352567.
the component did not provide the exception description.”
Hi , check your code from another app , like excel .
ITs most likely coding error , or the object is not well written or used.
g.
hi all,
got it resolved already, basically i call create excel codes twice, one on the reports.ini, second one on dataitem post data item…
Great , seems to me you can fix all your problems, hope this will mean lot to the community.
g.
