OLE Control of Automation Server error
Hi
I have an OLE Control or Automation Server error when trying to accept a payment in Navision. The flat file that my user is trying to accept is located on anetwork share. The user has access and has the drive mounted. The following error occurs when the users tries to accept and send the payment.
This message is for C/AL Programmers:
Could not create an instance of the OLE control or Automation server identified by GUID={0D54C20E-EAF1-43D4-8E72-19CC5916DFD1} 2.0:{1D9369E6-6DC3-4A81-B8DA-684F0308E9A1} Unknown Automation Server.Unknown Class.
Check that the OLE control or Automation server is correctly installed and registered.
Anyone know what to do? :slight_smile:
Mads
Something is probably not installed on their machine. Since those GUIDs do not return any results in Google it’s impossible to know what automation server is missing. I can only guess it is an add-on or custom object. The best thing to do is get a hold of your NAV Partner.
HI do you get Soltion for this Automation Server and OLE…please if get the solution please let me know i need this
Thank you.
Welcome to DUG Ajit,
Please Search always beforre posting your question
http://dynamicsuser.net/forums/p/25968/140697.aspx
