hi I have questions about OLAP: We don’t use web clients so my question is if web user is able to transfer, process and view olap cubes. Slawek
Hi Slawek, Not sure what you mean by web client. Perhaps do you mean Navision Axapta Web Deployment Client (NAWDC)? Please clarify. Regards, Harish Mohanbabu
hi Yes, I mean NAWDC. Slawek
Hi Slawek, In that case - yes - it should be possible to access & process OLAP cubes. Provided the user’s machine meets the requirements by setting up ODBC, installation of pivot service (i.e. if you opt for pivot table). NAWDC basically investigates the user’s machine whether an Axapta installation is present or not. If not, then it will install Axapta client in the user machine. If yes, then it will check presence of matching SP in the user’s machine. If not, then it will install the SP. Hope this helps, Harish Mohanbabu
