OLAP Cube creation failed
I try to create a cube file using tool which is downloded from olapcube.com. It is giving error and also i have few clarifications. if anyone have ideas about this could you please reply it.
1.I am not able to view the Stored Procedure Name when i connected to SQL Server.
However I am able to see tables and views name. Is it restricted ?
2.I used SQL view which having groups for a cube. When i try to build the cube it through error.
  1. How to do % calculation example:
Total Records: 100
Column X Y
Row 1 10 5
Row 2 20 30
For the above data O/P should come like below but it is not coming.
Column X Y
Row 1 10 % 5 %
Row 2 20 % 30 %
For the % calculation it tooks row count of particular columns.
It is not taking total records which is pulled to reoprts.
  1. Is there any parameter option so i can run pass the value to filter the records.
  2. Can i invoke the olap cube any of java applications or other applications .
  3. Is there available any variable concept so i can utilise in the calculations wherever i required.
Regards
Babu N
