During Table optimizition In Navison3.60SQL Client with NL3.10 object I received the following Error: [Microsoft][ODBC SQL Server Driver]Invalid Precision Value. State ID: HY104 Before testing all tables one by one, can anyone give me a clue how this error is caused?
Its about precision or lengths of fields when using parameters in ODBC. You need to know the table before you can look at the field meta data - did you not get the table name as part of the error? Usually, when there is a table related error you’ll get a message starting with “An error occured when accessing the xyz table”. Can you run the Client Monitor before table testing and see what the last SQL statement is before the error?
