ODBC Error
… retrieving an ODBC-Error 08004 No Permissions under Winnt; I’m loggend in as Admin; Trying to connect over a server in a Network is ok, trying to connect to a local database (or over a Server on a local database) doesn’t work.
What version of winnt is it, there are some issues with the newer 2000 versions. I believe there is an update on the Microsoft webpage, if thats the case. The only other thing would be to check the installation of the ODBC driver, see that it all ok.
