ODBC Error
Hi all
I was trying to login to Navison classic client through SQL server when i got this error " The following ODBC error occured " Error: [Microsoft][ODBC SQL Server] Timeout Expired State ID: HYT00
How can i solve the issue? Please help me out??
Subha
Hi subhavn
I think its a sink Problem…
just synchronise the login once and check.
Hi, Is it SQL 2005?
If yes, then please refer following link:
http://mibuso.com/blogs/kriki/2008/04/05/local-sqlserver-2005-with-windows-authentication/
no it SQL 2008
Is it a local server or remote? Can you connect from SQL Management Studio with the same server name?
Yes it is a local server. I can connect it from QL Management Studio with the same server name.
Just try with IP address in Server name. I hope it will resolve ur problem.
Yes I found that by using IP Address
