I have a table in another database. I wrote the codes to open the ODBC connection and the particular table.everything is fine.
There are 3 records in this table.
I can view them in the Info log also.
In my AOT, i have created a similar Table. When I run the code,it inserts, the 1st record successfully. Then it gives error
“Cannot execute the required operation, The operation failed”
[Microsoft][SQL Native Client]Invalid Descriptor Index
Any idea what could be wrong…
Here is my code.
public server static void GetHeader()
ODBCConnection conn;
LoginProperty loginprop;
Resultset resultSet; //Result of excecution
Statement myStatement;
SqlStatementExecutePermission perm;
str sql_Header;
int i;
MenaAxJournalHeader menaAxJournalHeader;
sql_Header = strfmt(‘select * from MenaAxInterimHeader where valid = 1’); //Sentence to execute in SQLServer-database
//Get ODBC connection
loginprop = new loginproperty();
loginprop.setServer(‘ERP-SERVER’); //Variables to connection
loginprop.setDatabase(‘MenaAXInterimDB’); //Variables to connection
//Create a connection to external database
try
conn = new ODBCConnection(loginprop);
catch
throw error(“Error creating ODBC connection”);
// Execute the sentence
if(conn)
if(sql_Header == “”)
throw error(“No sql statement to execute”);
//Assert permission for executing the sql string
perm = new SqlStatementExecutePermission(sql_Header);
//Check for permission to use the statement
perm.assert();
perm.owner();
//Prepare the sql statement
myStatement = conn.createStatement();
resultset = myStatement.executeQuery(sql_Header);
i = 0;
while (resultSet.next())
MenaAxJournalHeader.JounrnalNum = resultSet.getString(1);
MenaAxJournalHeader.JournalDate = resultSet.getDate(2);
MenaAxJournalHeader.JournalDesc = resultSet.getString(3);
MenaAxJournalHeader.Valid = resultSet.getInt64(4);
MenaAxJournalHeader.insert();
//close the connection
if (resultset)
resultset.close();
if(mystatement)
mystatement.close();
//End the scope of assert statement
codeaccesspermission::revertAssert();
