I am working on a form which will print to a label. when i hit my print button I get the message “Object reference not set to an instance of an object.”
Below is my code.
[FormControlEventHandler(formControlStr(MJMNeTubingLabel, MJMPrintTubingLabel), FormControlEventType::Clicked)]
public static void MJMPrintTubingLabel_OnClicked(FormControl sender, FormControlEventArgs e)
FormRun formRun = sender.formRun();
FormDataSource formDataSource = sender.formRun().dataSource(“SalesTable”);
UserInfo userInfo;
MJMLabelFormatSupport UsersLabel;
MJM_ScanFolder ScanFolder;
// this needs to come in as variable
str descript;
//On the TubingRound Label
FormComboBoxControl formTubingLabelFormat = FormRun.design(0).controlName(“MJMTubingLabel_TubingLabelFormat”);
FormStringControl formSalesId = formRun.design(0).controlName(“MJMFinShipLabel_SalesId”);
FormStringControl formCustomerRef = formRun.design(0).controlName(“MJMFinShipLabel_CustomerRef”);//OrderNum
FormStringControl formCageNum = formRun.design(0).controlName(“MJMFinShipLabel_CageNum”);
FormStringControl formSpoolPartNumber = formRun.design(0).controlName(“MJMTubingLabel_MJMSpoolPartNumber”);//Manual enter
FormStringControl formExternalItemId = formRun.design(0).controlName(“MJMFinShipLabel_ExternalItemId”);//PartNum
FormStringControl formLot = FormRun.design(0).controlName(“MJMFinShipLabel_Lot”);
FormStringControl formAWGSize = FormRun.design(0).controlName(“MJMFinShipLabel_AWGSize”);
FormStringControl formSalesUnit = FormRun.design(0).controlName(“MJMFinShipLabel_SalesUnit”);
FormStringControl formReelNum = FormRun.design(0).controlName(“MJMFinShipLabel_ReelNum”);
FormRealControl formNumPieces = FormRun.design(0).controlName(“MJMFinShipLabel_NumPieces”);
FormRealControl formLength = FormRun.design(0).controlName(“MJMFinShipLabel_Length”);
FormRealControl formTopPc = FormRun.design(0).controlName(“MJMFinShipLabel_TopPc”);
FormDateControl formMFGDate = FormRun.design(0).controlName(“MJMFinShipLabel_MFGDate”);
FormRealControl formGross = FormRun.design(0).controlName(“MJMFinShipLabel_Gross”);
FormRealControl formTare = FormRun.design(0).controlName(“MJMFinShipLabel_Tare”);
FormRealControl formNet = FormRun.design(0).controlName(“MJMFinShipLabel_Net”);
FormIntControl formNumberOfLabels = FormRun.design(0).controlName(“MJMFinShipLabel_NumberOfLabels”);
//On the TubingSquare Label
FormStringControl formItemNo = formRun.design(0).controlName(“MJMTubingLabel_MJMItemNo”);
FormStringControl formOrderNumber = formRun.design(0).controlName(“MJMTubingLabel_MJMOrderNumber”);
FormStringControl formPartNumber = formRun.design(0).controlName(“MJMTubingLabel_MJMPartNumber”);
FormStringControl formMfgPartNum = formRun.design(0).controlName(“MJMTubingLabel_MJMMFGPartNo”);//Manual enter
FormStringControl formBulkWorkOrder = formRun.design(0).controlName(“MJMTubingLabel_MJMBulkWorkOrder”);
FormStringControl formMfgLotNum = formRun.design(0).controlName(“MJMTubingLabel_MJMMFGLotNum”);//Manual enter
FormStringControl formRev = FormRun.design(0).controlName(“MJMTubingLabel_MJMRevision”);
FormStringControl formDescription = FormRun.design(0).controlName(“MJMTubingLabel_MJMTubingDescription”);
FormStringControl formOutsideDmter = formRun.design(0).controlName(“MJMTubingLabel_MJMOutsideDmter”);//Manual enter
//FormRealControl formLineNum = FormRun.design(0).controlName(“MJMFinShipLabel_LineNum”);
//FormStringControl formItemId = formRun.design(0).controlName(“MJMFinShipLabel_ItemId”);//MfgPartNum
date MFGDate = str2Date(formMFGDate.valueStr(),321);
Str tubingLabel = formTubingLabelFormat.valueStr();
//get the user mane to find format
select * from userInfo
where userInfo.name == xUserInfo::find().name;
//info(strfmt("%1 %2", xUserInfo::find().name, userInfo.id ));
// this is create a unque key for the format file
System.DateTime dateTime = System.DateTime::get_UtcNow();
str utcTimeAsStr = dateTime.ToString(‘yyyyMdHHmmss’);
// find user template and printer
if(tubingLabel == enum2Str(MJMTubingLabelFormat::TubingRoundLabel))
select * from userslabel
where UsersLabel.User == userInfo.id && UsersLabel.LabelFormat == “NTRL”;
else if(tubingLabel == enum2Str(MJMTubingLabelFormat::TubingSquareLabel))
where UsersLabel.User == userInfo.id && UsersLabel.LabelFormat == “NTSL”;
else if(tubingLabel == enum2Str(MJMTubingLabelFormat::CableSquareLabel))
where UsersLabel.User == userInfo.id && UsersLabel.LabelFormat == “NTCL”;
// get location to drop files
select * from ScanFolder
where ScanFolder.MJM_ScanFolder_Name == “Bartender”;
// now we create and write the file
System.IO.StreamWriter sw;
InteropPermission perm = new InteropPermission(InteropKind::ClrInterop);
perm.assert();
// file name and location
sw = new System.IO.StreamWriter(strRTrim(ScanFolder.MJM_ScanFolder_Path) + userslabel.User + utcTimeAsStr + “.dat”);
// header
sw.WriteLine("%BTW% /f=" + UsersLabel.LabelTemplate + " " /d="%Tigger File Name%" /PRN=" " + UsersLabel.LabelPrinter + “” /r=3 /p /dd /c=" + formNumberOfLabels.valueStr()+ “”");
sw.WriteLine("%END%");
//variable names
sw.WriteLine(“AwgSize, Cage, CustomerPN, SpoolPartNumber, CustomerPo, Lot, Gross, Tare, Net, UOM, ReelNum, NoPcs, Length, TopPiece, SalesOrder, Mfgdate, AwgSizeDesc, CageDesc, CustomerPNDesc, SpoolPartNumberDesc, CustomerPoDesc, LotDesc, GrossDesc, TareDesc, NetDesc, UOMDesc, ReelNumDesc, NoPcsDesc, LengthDesc, TopPieceDesc, SalesOrderDesc, MfgdateDesc”);
else if(tubingLabel == enum2Str(MJMTubingLabelFormat::TubingSquareLabel))// Tubing Square Label
sw.WriteLine(“OrderNo, ItemNo, PartNum, Rev, MfgLotNo, MfgPartNo, SalesOrder, Description, BulkWorkOrder, Quantity, OrderNoDesc, ItemNoDesc, PartNumDesc, RevDesc, MfgLotDesc, MfgPartDesc, SalesOrderDesc, DescriptionDesc, BulkWorkOrderDesc, QuantityDesc”);
else if(tubingLabel == enum2Str(MJMTubingLabelFormat::CableSquareLabel))//Cable Square Label
sw.WriteLine(“OrderNo, ItemNo, PartNum, Rev, MfgLotNo, MfgPartNo, SalesOrder, Description, MfgDate, OutsideDmter, Quantity, OrderNoDesc, ItemNoDesc, PartNumDesc, RevDesc, MfgLotDesc, MfgPartDesc, SalesOrderDesc, DescriptionDesc, MfgDateDesc, OutsideDmterDesc, QuantityDesc”);
Descript = System.Text.RegularExpressions.Regex::Replace(formDescription.valueStr(), “”", “”);
sw.WriteLine(
“”" + formAWGSize.valueStr() + “”,"" +
formCageNum.valueStr() + “”,"" +
formExternalItemId.valueStr() + “”,"" +
formSpoolPartNumber.valueStr() + “”,"" +
formCustomerRef.valueStr() + “”,"" +
formLot.valueStr() + “”,"" +
formGross.valueStr() + “”,"" +
formTare.valueStr() + “”,"" +
formNet.valueStr() + “”,"" +
formSalesUnit.valueStr() + “”,"" +
formReelNum.valueStr() + “”,"" +
formNumPieces.valueStr() + “”,"" +
formLength.valueStr() + “”,"" +
formTopPc.valueStr() + “”,"" +
formSalesId.valueStr() + “”,"" +
strFmt("%1/%2/%3",mthOfYr(MfgDate),dayOfMth(MfgDate),Year(MfgDate)) + “”,"" +
“AWG Size:” + “”,"" +
“Cage #:” + “”,"" +
“Customer P/N:” + “”,"" +
“Part #:” + “”,"" +
“Customer PO #:” + “”,"" +
“Lot #:” + “”,"" +
“Gross:” + “”,"" +
“Tare:” + “”,"" +
“NET:” + “”,"" +
“Unit:” + “”,"" +
“Reel #:” + “”,"" +
“No Pcs:” + “”,"" +
“Length:” + “”,"" +
“Top Piece:” + “”,"" +
“Sales Order:” + “”,"" +
“Mfg Date:” + “”,"");
sw.Flush();
sw.Close();
sw.Dispose();
sw.WriteLine(
“”" + formOrderNumber.valueStr() + “”,"" +
formItemNo.valueStr() + “”,"" +
formPartNumber.ValueStr() + “”,"" +
formRev.valueStr() + “”,"" +
formMfgLotNum.valueStr() + “”,"" +
formMfgPartNum.valueStr() + “”,"" +
descript + “”,"" +
formBulkWorkOrder.valueStr() + “”,"" +
“Order No:” + “”,"" +
“Item No:” + “”,"" +
“Part No:” + “”,"" +
“Rev:” + “”,"" +
“MFG Lot No:” + “”,"" +
“MFG Part No:” + “”,"" +
“Description:” + “”,"" +
“Bulk Work Order:” + “”,"" +
“Quantity:” + “”,"");
sw.Flush();
sw.Close();
sw.Dispose();
sw.WriteLine(
descript + “”,"" +
formMFGDate.valueStr() + “”,"" +
formOutsideDmter.valueStr() + “”,"" +
“Rev:” + “”,"" +
“MFG Date:” + “”,"" +
“O.D.:” + “”,"" +
sw.Flush();
sw.Close();
sw.Dispose();
