the problem is that I was able to customize all tables 2 days ago!
I donot know what happened ??
yes, its a cronus license…
Upload/Change your developer license
what do you mean by change your develper license?
Have you checked your license by goiing to Tools–Lincense Information
Here you can see the license
If it is showing cronus licnese then you need to change this with your license.
In your screenshot, bottom left you have upload and change options…
so click change and select your company license…
Hi Mohamed,
Follow these steps.
Open demo database. Then File → database → Information. From Database Information window, remember server name and database name.
Go to SQL Server and find the database. Expand database -->select security and expand it → select users and expand it → Check wether your user name existing as a windows login name. If not create a database login and assign it into the database.
Go to your demo database. Tools → Security → Windows login/database login → see wether your login is there. if not add it.
Then select your login → Roles → in Roles form lookup Roles ID form and select ‘SUPER’ role.
Under security select your login → Tools → Security → do ‘sinchronize single login’.
6 . Go out from the database and again login as the new user you created. If you use Windows login, automatically you will login to the system, otherwise you have to give user name and password of the new user.
