My requirement is Numeric field till 20
i tried using Int64 it takes only 19 digits
so i took one string type gave size to 20 now in form->DS->table->field->method->validate
i am trying to restrict to enter any character but only number upto 20 digits,
unable to get hold of all characters can you please suggest how can i achieve this
Thanks in Advance
The maximum value that Int64 can hold is 9,223,372,036,854,775,808. If you need a higher value, you can combine two fields together.
Override validateField() method if you want to reject certain values.
Thanks martin … but the issue is fixed i took string field gave size to 20 and restricted from
entering characters by using strkeep() …
This below was the piece of code
public boolean validate()
int y,y1;
str x,p;
boolean ret;
ret = super();
y= strLen(a_String.text());
x = a_String.text();
p = strKeep(x,“1234567890”);
y1= strLen(p);
if(y1!=y)
throw error(“Please enter only numeric values”);
return ret;
