In AX 2012, I have created new number series for Sales Quotations and trying to attach the same from AR parameters.
But at that time system gives me “Unable to find a unique Number sequence code record corresponding to the entered values.” error.
What is the other set up which is required to complete.?
Jainal
Hello All,
Kindly help in the above error.
You have to add one more segment called “Company” in the number sequence form and it should be assigned to the current company account. This setup will make the number sequence record saved.
