Number Sequence
The number sequence i created increment even it is not save in the table.
Please help me to fix this problem. thanks
I am confused by the post, is the number sequence not saving in the table that it was created in?
There are a number of things this could be, check the number sequence set up, and the number sequence class you place the code in to create the number sequence - there are several of these so ensure it is within the correct number sequence class.
Perhaps going through a number sequence creation guide will assist with your problem, there is such a thing in the book Dynamics AX 2009 Getting Started, you can find the pdf online free.
