hi all
i wanna set a number sequence to customer account
is it possible to do tat?
if yes means how to do tat?
pls any one help me
thanx in advance
hi all
pls any one help me
thanx in advance
As standard you can set each customer to call a different number sequence per invoice. There were also yesterday posts and external links for this solution for order numbers so depending upon what you require I suggest you search the forum.
HI for creating the numbersequence have a look in to this blog.
In Ax u can create your desired number sequences for your customer account , for this please fallow the below path
Go to basic module > Set up > Numbere sequences > here define u r number sequences and
go to Accounts receivable > Set up > Parameters > Click on number sequences tab > there you have to assign the number sequences which u were defined in the basic module.
