Hi everybody,
I’ve got a problem concerning the number sequence.
When importing a new ledger journal by a excel template. After the import everything works fine no errors, the journal is verified with no errors an cann be transfered. Despite the number sequence ist corrupt, e.g. when creating a new journal the same journal number is applied as in the imported excel journal. When checking the number sequence, I discovered that this journal number is in the NumberSequenceList marked as ‘undecided’. After deleting this record the number sequence work again.
Has anybody run into this situation, and has solved it?
Sorry forgot to mention this happens on AX 4.0 build number 4.0.2501.116
Greetings
Ralph
