Number sequence issue with General Journal
Hi ,
I have a form and which has all the fields for journal entry. It has a button “Transfer to Journal”. In the Click method of that button , i have written the following code:
void clicked()
LedgerJournalName LedgerJournalName;
ProjTable ProjTable;
RecordInsertList recordInsertList = new RecordInsertList(tableNum(LedgerJournalTrans));
RecordInsertList recordInsertList1 = new RecordInsertList(tableNum(LedgerJournalTrans_Project));
RecordInsertList recordInsertList2 = new RecordInsertList(tableNum(LedgerJournalTable));
LedgerJournalTable jourTable;
LedgerJournalTrans jourTrans;
LedgerJournalNameId LedgerJournalNameId= ‘Effort’;
LedgerJournalTrans_Project LedgerJournalTrans_Project;
LedgerJournalTableData jourTableData;
LedgerJournalTransData jourTransData;
LedgerJournalStatic jourStatic;
UploadFile UploadFileLoc;
NumberSeq numberSeq;
boolean flag=true;
ttsbegin;
breakpoint;
ledgerJournalEngine = new LedgerJournalEngine();
select firstonly LedgerJournalName where LedgerJournalName.JournalName ==LedgerJournalNameId;
jourTableData = JournalTableData::newTable(jourTable);
jourTable.JournalNum = jourTableData.nextJournalId();
// jourTable.JournalType = LedgerJournalType::
jourTable.Name = ‘Effort’;
jourTableData.initFromJournalName(LedgerJournalName::find(jourTable.Name));
jourStatic = jourTableData.journalStatic();
jourTable.insert();
// jourTable.clear();
// select LedgerJournalName where LedgerJournalName.JournalName == LedgerJournalNameId;
// if(!LedgerJournalName)
// error(‘Journal Not found’);
// jourTable.Name=‘Effort’;
// jourTable.initFromLedgerJournalName(LedgerJournalNameId);
// jourTable.JournalNum = NumberSeq::newGetNum(LedgerParameters::numRefJournalNum()).num();
// jourTable.insert();
while select UploadFileLoc
where UploadFileLoc.Selection == NoYes::Yes
breakpoint;
jourTransData = jourStatic.newJournalTransData(jourTrans,jourTableData);
jourTransData.initFromJournalTable();
jourTrans.initValue();
jourTrans.CurrencyCode = UploadFileLoc.UploadCurrency;
jourTrans.validateField(fieldnum(LedgerJournalTrans, CurrencyCode));
jourTrans.TransDate = UploadFileLoc.Date;
jourTrans.AccountType= UploadFileLoc.AccountPlType;
jourTrans.validateField(fieldnum(LedgerJournalTrans, AccountType));
jourTrans.AccountNum = UploadFileLoc.AccountNum;
jourTrans.validateField(fieldnum(LedgerJournalTrans, AccountNum));
jourTrans.OffsetAccountType=UploadFileLoc.OffsetAccountType;
jourTrans.validateField(fieldnum(LedgerJournalTrans, OffsetAccountType));
jourTrans.OffsetAccount = UploadFileLoc.OffsetAccount;
jourTrans.validateField(fieldnum(LedgerJournalTrans, OffsetAccount));
jourTrans.AmountCurDebit=UploadFileLoc.AmountCurDebit;
jourTrans.validateField(fieldnum(LedgerJournalTrans, AmountCurDebit));
jourTrans.AmountCurCredit =UploadFileLoc.AmountCurCredit;
jourTrans.validateField(fieldnum(LedgerJournalTrans, AmountCurCredit));
jourTrans.Txt=UploadFileLoc.Text;
jourTrans.ExchRate = Currency::exchRate(jourTrans.CurrencyCode);
jourTrans.validateField(fieldnum(LedgerJournalTrans, ExchRate));
jourTrans.Dimension[1]=UploadFileLoc.Dimension[1];
jourTrans.Dimension[2]=UploadFileLoc.Dimension[2];
jourTrans.Dimension[4]=UploadFileLoc.Dimension[4];
jourTrans.Dimension[6]=UploadFileLoc.Dimension[6];
jourTrans.Dimension[8]=UploadFileLoc.Dimension[8];
numberseq =NumberSeq::newGetVoucherFromCode(LedgerJournalName.VoucherSeries);
jourTrans.Voucher = numberseq.voucher();
ledgerJournalEngine.amountCurDebitModified(jourTrans);
ledgerJournalEngine.clearTaxAmountCache(jourTrans);
ledgerJournalEngine.cashDiscCodeModified(jourTrans);
jourTrans.modifiedField(fieldnum (LedgerJournalTrans,AmountCurDebit));
if(UploadFileLoc.AccountPlType==LedgerJournalACType::Project)
breakpoint;
LedgerJournalTrans_Project.CategoryId=UploadFileLoc.CategoryId;
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project, CategoryId));
LedgerJournalTrans_Project.LinePropertyId=UploadFileLoc.LinePropertyId;
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project, LinePropertyId));
LedgerJournalTrans_Project.EmplId=UploadFileLoc.EmplId;
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project,EmplId));
LedgerJournalTrans_Project.SalesCurrencyId=UploadFileLoc.UploadCurrency;
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project,SalesCurrencyId));
LedgerJournalTrans_Project.SalesPrice=UploadFileLoc.SalesPrice;
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project,SalesPrice));
LedgerJournalTrans_Project.CostPrice=UploadFileLoc.CostPrice;
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project,CostPrice));
LedgerJournalTrans_Project.Qty=UploadFileLoc.Quantity;
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project,Qty));
LedgerJournalTrans_Project.RefRecId=jourTrans.RecId;
recordInsertList1.add(LedgerJournalTrans_Project);
LedgerJournalTrans_Project = null;
// LedgerJournalTrans_Project.insert();
// else
// flag=false;
// throw error(“Validation failed for Project Type.Please fill mandatory fileds”);
if (jourTrans.validateField(fieldnum(LedgerJournalTrans, CurrencyCode)) &&
jourTrans.validateField(fieldnum(LedgerJournalTrans, AccountNum)) &&
jourTrans.validateField(fieldnum(LedgerJournalTrans, AccountType))&&
jourTrans.validateField(fieldnum(LedgerJournalTrans, OffsetAccount))&&
jourTrans.validateField(fieldnum(LedgerJournalTrans, OffsetAccountType)) &&
jourTrans.validateField(fieldnum(LedgerJournalTrans, AmountCurDebit)) &&
jourTrans.validateField(fieldnum(LedgerJournalTrans, AmountCurCredit))&&
jourTrans.validateField(fieldnum(LedgerJournalTrans, ExchRate) ))
if(UploadFileLoc.AccountPlType!=LedgerJournalACType::Project || (UploadFileLoc.AccountPlType==LedgerJournalACType::Project &&
(LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project, CategoryId)) &&
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project, LinePropertyId)) &&
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project, SalesCurrencyId)) &&
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project, SalesPrice)) &&
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project, CostPrice)) &&
LedgerJournalTrans_Project.validateField(fieldnum(LedgerJournalTrans_Project, Qty)))))
// jourTrans.insert();
recordInsertList.add(jourTrans);
jourTrans = null;
// recordInsertList2.add(jourTable);
// jourTable=null;
else
flag=false;
else
flag=false;
throw error(“Validation failed”);
UploadFileLoc.selectForUpdate(true);
UploadFileLoc.delete();
info(strfmt(‘Journal Id:%1’,jourTable.JournalNum));
if(flag)
if(recordInsertList1.usageCount() > 0)
recordInsertList1.insertDatabase();
if(recordInsertList.usageCount() > 0)
recordInsertList.insertDatabase();
// if(recordInsertList2.usageCount() >0)
// recordInsertList2.insertDatabase();
else
info(strfmt(‘Journal Id:%1 creation failed. Please find the above error messages for failure’,jourTable.JournalNum));
ttscommit;
UploadFile_ds.refresh();
UploadFile_ds.reread();
UploadFile_ds.research();
All the validations are going correctly. However i have one issue. Even if the validation fails saying the category id is not correct, a Journal id is created. However when i check the journal table, the id doesnot exist. So i want to ensure that no journal id is creaed when the validation fails . It should only be created when the validation completely pass.
Code for LedgerJournalTableData which you see above in the code is as follows:
void create( boolean _doInsert = false, boolean _initVoucherList = true)
lastLineNum++;
journalTrans.LineNum = lastLineNum;
if (journalTableData.journalVoucherNum())
this.initVoucher( lastVoucher, false, _initVoucherList);
this.addTotal(false, false);
if (_doInsert)
journalTrans.doInsert();
else
journalTrans.insert();
lastVoucher = journalTrans.Voucher;
Can anyone please help me quickly
Saurav
any help guys…
