number of format barcode number
hey there i’m facing this problem as you see here formats of barcod number not shown well i mean the numbers
any solve for this problem??!!
or if there any way to remove number only from barcode number?!
i already do customization to (Peripherals.dll) from SDK CU9 Peripherals>Printer
to fix merging issue
and as you see here i change barcode to barcode128
because my barcode reader can’t recognize barcode39
Your code is not in X++. If you ask for X++ this’s the solution:
display BarCodeString ServiceOrderbarCode()
Barcode barcode;
barcode = Barcode::construct(BarcodeType::Code39);
barcode.string(true, ServiceOrder.ServiceOrderId);
barcode.encode();
return barcode.barcodeStr();
You can use Font - BC C39 3 to 1 HD Wide as font. You can’t print barcode scanner readable barcodes with all font sizes, you have to find out with try…
I see you’re using AX POS. Even you use C# or some language else you have to encode barcode string before print. In the other case, you can see barcode at paper but can’t read with reader.
thanks for replay
i really use SDK CU9 to fix many things like margin problem and now this problem about barcode
