Hmm. In former versions this was handled by the mapihandler, and it is kinda hard to figure out exactly what automation to use. It should be installed when running the install, but i doubt it is.
The problem is it tells you have an unknown class(when you open a std. codeunit 397 and go to OSendmail subtype)? Means your computer does not hold the custom control needed(you find it in tools, custom controls in navision).
Sadly i have the same problem so i cant tell you what automation class/subclass is needed…
Have you tried running RegSvr32 on the OLHandler.dll?
There is a known issue with OLHandler and Nav. I got the latest HF from MS just last week.
BUT! The OLHandler works fine. The Fin.Exe has its own problems though, so I sent a bug report back to MS. You can still use the new Olhandler.dll without the fin.exe. Well my customer could.
OLhandler.dll:-
File Version : 4.0.0.21871
If you do not have this version go get it from MS.
PS!
If you have a developer license to check if the automation Controller exsists do the following.
Create new form using the Wizard. Base it on the table “Automation” (Just type it in).
Make sure the form type is “Tabular-Type Form”, hit OK.
On the next screen hit the ‘>>’ button then press preview.
You should get a list of all the automation controllers.
In the TypeLibFile column press F7 and enter the following filter @olhandler
If nothing shows the OLHandler is not registered. If it does that the path in “TypeLibFile” will tell you where to look for the .dll
That can become confusing, the user expects to see “NS Outlook Synchronization Handler” in the Custom Control List, but it won’t appear.
Custom Control comes from “OLE Handler” and NS Outlook is in “Automation”
The “Browse” will register it as needed, just won’t appear in the list.
The other things to bear in mind, are you should set the browse to view “All files .” as OLHandler is a .dll not an .OCX
Also the .dll should be copied to your Navision Client Directory otherwise the Automation Reference will point to the path on the CD. I just tried it [:)]
