Hi I have a production order that when I try to post a consumption journal to it says the item is not on inventory. This is quite clearly there… any ideas? Thanks Fleur[:p]
Hi Fleur, If you have the stock of item and if you are unable to post the consumption journal, then just check whether you have specified the location code. Regards Srini
