I have a many to many situation and need to get a single record (Document No. + posting date) for the multiple entries from the value entry table where journal entries used the same document no. I am not finding the original entry to be able to total the Cost posted to G/L value.
I am sure this is a simple thing but i cannot see what I am doing wrong.
(Dataitem = Value Entry) clear(ValEntryTemp); ValEntryTemp.SETCURRENTKEY(“Document No.”,“Posting Date”); ValEntryTemp.SETRANGE(“Document No.”,“Document No.”); ValEntryTemp.SETRANGE(“Posting Date”,“Posting Date”);
*IF ValEntryTemp.FIND(’-’) THEN BEGIN //*This is not working - not finding the first record ValEntryTemp.“Cost Posted to G/L” := ValEntryTemp.“Cost Posted to G/L” + “Cost Posted to G/L”; ValEntryTemp.MODIFY; END ELSE BEGIN ValEntryTemp.INIT; ValEntryTemp.COPY(“Value Entry”); END;
The COPY should insert the first record and then that record is modified by the next Value Entry record where the Document Number and Posting Date is the same. At least that is what I am trying to achieve.
Use Transferfields instead of copy. Copy also copies filters from the other record and can lead to errors by excess of filters.
I don’t know you do that, but before using that temp table you should make a DELETEALL.
In general, copying filters should not be a problem if you have a good programming style (always using RESET (or clear),SETCURRENTKEY,SETRANGE/SETFILTER).
I even use tmpTemptable := “Value Entry”; and never had any problems.
The RESET+DELETEALL before filling up the temptable is a good programming style. So someone else sees immediately that the table is emptied at that point.
