Not able to post the entries
hi,
i’m getting below error message while posting the entries.
“An exchange rate cannot be found for exchange rate type Test between currencies INR and KWD on exchange date 06/26/2014”
i’ve already defined ‘Currency Exchange Rates’ and ‘Exchange Rate Types’ in GL setups, and also define the setups in Ledger setups, even though i’m getting the same error.
I’m using AX 2012.
Can any one suggest me the solution for this error.
thanks in Adv.
Once again cross check that you have defined the exchange rate for INR VS KWD for the Exchange rate type specified in the ledger only. Also see if there is any Date is imposed on the setup and make necessary changes accordingly.
Please check whether the following link helps :
http://blogs.msdn.com/b/axsupport/archive/2012/09/25/quot-an-exchange-rate-cannot-be-found-for-exchange-rate-type-xxx-between-currencies-yyy-and-zzz-on-exchange-date-quot-when-you-attempt-to-process-in-microsoft-dynamics-ax-2012.aspx
