I am not able to delete a folder / directory using System.Io.Directory::Delete(Directory), the folder is NOT EMPTY.
Do you get any error?
No
Have you tired by deleting the files and then the folder?
Files also not getting deleted, as I am getting error as “File opened in Dynamics Ax.”
What type of files are they? How are you dealing with them before deleting?
From WORD, I converted those files into Password protected PDF files and after my work, I am trying to delete the files (Password protected PDFs).
I am getting the following error:
The process cannot access the file because it is being used by another process
It means that the file was not properly released/closed before deleting.
Try to use FileIOPermission class object, see the documentation and example
msdn.microsoft.com/…/system.security.permissions.fileiopermission(v=vs.110).aspx
public server static boolean deleteFile(filename _filename)
FileIOPermission FileIOPerm;
FileIOPerm = new FileIOPermission(_filename,‘w’);
FileIOPerm.Demand();
System.IO.File::Delete(_Filename);
No, it’s not about permissions. The message clearly says that the file can’t be deleted because it’s currently open in an application.
