Non SQL Dynamics Database
Hi Guys,
I only have experience of the SQL version of Dynamics NAV 2009 and the project is nearing it’s end.
For the purposes of an integration I use standard SQL lookups from the back end database to aquire certain data, all works fine:
select [Quantity],[Type] from dbo.[CRONUS International Ltd_$Purchase Line] where [Description] like ‘Shelf’ etc etc …
However, how would one aquire the same data in the same way using the non SQL version?
Many thanks in advance.
Although I’ve never actually done it, you can use C/ODBC and/or C/FRONT to get the data. As for the actual “doing it”, I’m not sure.
Thanks Matt, that’s all I needed to know. :slight_smile:
