No work items for purchase requisition workflow
we could not find the work items in the PR (preparer) form as showing below screenshot after submitting. we are facing this issue in Ax 2009 Purchase Requisition work flow. can you please guide us.
Do other workflow work? Do you have workflow batch jobs running?
Why is this question in the development forum? Are you making some changes in this area?
Hi Martin, Thanks for reply
First time we are using this PR work flow before that none of workflows are using. As per functionality the setup has done fine and run the workflow tutorial. we haven’t change any thing in the setup. is there any technical issue ?
As I mention, I would check that the workflow batches are running. If you don’t have the workflow logic running, you can’t expect it to work.
