I am getting an error: “You cannot assign numbers greater than 9999999999 from the number series M-PLAN.” in the Planning Worksheet when I calculate a plan. The 999999999 is the Ending No. in the M-PLAN series (Planned Order No.s). The debugger does not stop when I turn it on before calculating a plan. (I put a breakpoint on the last line of the report, and the debugger reaches it without any protest, and then gives the error message). This error happened only after I customised the Requisition Line table, but none of my new code is being executed, and it doesn’t seem like Navision is actually trying to generate 99999999999 requisition lines, so I’m baffled. Any suggestions about what the problem could be? Thanks, Alastair
Hi Alastair, may be it helps, if you close the Main Menu and reopen it, before you test/debug your changes. which version do you use? br Josef Metz
Hi Josef, I realised that the M-PLAN no. series had a Warning No. of 101995, so as soon as this was exceeded, I started to get warning messages (not error msgs, which is why the debugger did not trap them). Thanks for your suggestion. Btw, I’m using Navision 4.0.
