No. Series - Best practice
I need an example of how to deal with no. series the best way! Should it be done directly on the page (which event then?) or via a table-trigger? What about “losing” numbers when cancelling a creation?
I’ve done a lot of research, but I couldn’t find a appropriate solution…
Thanks in advance!
What are you trying to do? Are you looking to modify the behavior of a standard table that uses a “No. Series”? Or trying to implement a “No. Series” on a custom table? Notice I say “Table” as that is where the “No. Series” logic is. If you are adding to a custom table, that is where your logic should go. Use a base table as a guide.
Hi, hope this will help.
https://yzhums.com/2278/
