I am currently testing Production Order cycle in AX 2009, when I am about to post the journal reported as finished I get this error of “No record found in the Item/version price per cost group table. Transfer a cost price for this item.” Can you help me to find resolution with these? When I am setting cost price for the, the system requires me to indicate item dimensions but the field Locations and Warehouse is grayed and I can’t fill it up… Do I miss something?
I tried two ways in inputting the cost price, first thru Item Details > Price/Discount Tab and also manually through setting cost version Price tab but the problem is I can’t activate the cost version because it requires setting-up dimensions and both Warehouse and Locations are grayed. The fallback principle is NONE. Is this related to Route? I don’t set-up the route for this production order.
I tried two ways in inputting the cost price, first thru Item Details > Price/Discount Tab and also manually through setting cost version Price tab but the problem is I can’t activate the cost version because it requires setting-up dimensions and both Warehouse and Locations are grayed. The fallback principle is NONE. Is this related to Route? I did not set-up the route for this production order.
Warehouse and Location are irrelevant to the cost in this instance.
Is hte cost on the Pending or Active tab?
Does the item have a cost on the Price/Discount tab? If it does and the Fallback principle was active the system would use this as the RAF WIP cost for the item.
The issue is you have not told the system the cost of the item, so it does not want to book it in.
For the selected item, the Warehouse and Location inventory dimensions may be set as mandatory or Active. Otherwise the problem may be due to the user might have changed the Dimension group code which is attached to the selected item.
