Hello,
Greetings to you.
In the purchase orders the No.printed is always 0 when I print the order.
It should be >0 when I print it but it is always zero.
Hello,
Greetings to you.
Which version of NAV and exactly which report?
If you are using a customized purchase order report, then make sure that it actually calls the code which updates the no. printed field.
Version 9, Report 405 Order.
In this report in the CopyLoop - OnPostDataItem trigger there is a function
IF NOT CurrReport.PREVIEW THEN
PurchCountPrinted.RUN(“Purchase Header”);
This should do the summation of the No.printed.
Yes. Then you could try running the report with the debugger turned on, to see if/why it is not updating the number.
And remember that it does not update when you select preview…
