I have developed custom form for our users. Everything works great when i run it using dev. license. When using the form in prod. environment the users
cant run the form. Dialog says something like “you are not authorized to run form xxxxx”
I not very good at licenses and permissons in Nav but is it a licenseproblem? We are running nav 3.6 and we have granule 8,300 Application objects - Forms (100) ---- 1
We are using windows auth and I have set up a role for the specific form and proper permissions for it. (read, write, execute, edit, delete)
The standard range that ships with most licenses is 50000 - 50099 for granule 7,120 Form Designer
You have purchased 100 extra object with granule 8,300 - please contact the partner who ordered the extra granule for the number assignment. It is not uncommon that the granule is purchased without the number range being assigned. This is easy to fix and the good news it’s free [:)]
