No of copies of a report
Hi. I have a label printer, called Avery 5.4, connected to Navision. If i were to print 100 labels, i would normaly use a integer loop, and set max iteration to 100. This would create 1 print job with 100 pages in it. The Avery printer interpret this as 100 jobs, which is wrong What I need to do, is create 1 print job, with 100 copies of the job. I can do this by printing 1 label, and in the windows dialog, set 100 copies. The printer will then see this as 1 job, with 100 copies, which is correct. So, the big question is, how do I control the no of copies from Navision? I need to pull this of, or the customer will have no use for Navision in this scenario. So, any, and I mean any thoughts on this, is highly welcome. Best regards, Thomas Jensen
Hi, is this printer specific, or would you have the same thing happening with other printers as well? regards Daniel
It’s all in the registry… export the registry, change the printer properties, export the registry, find the diff. with beyond compare search here or on mibuso for a topic; howto change registry
