Does not look to me like you have logged in to SFDC yet, so no jobs would be visible. These jobs would then be those sceduled against you as a work centre from memory on the SFDC Employee and WC relationship, yours are scehduled across different work centres, so you would not see them.
I am trying to register the job based on the clock in and clock out time, I clock in and clock out using SFC module, F3 button, but the time is not captured any where in the production order, my question is how it gets linked to productin order and where can i see that?
It is Shop Floor Control (SFDC is just shop floor data collection which is the screen you posted), it is the module you are in. You have not logged into the screen you are in, you need to define your employee number and then log into it.
i read one Microsoft’s book for SFC, in that they given you just select Warehouse, site & workcenter so it will list all scheduled job. i have past that screen-shot from book here we can see employee number comob is empty.
there is some parameter i am missing to fill? and yes i have also tried with Employee login then also it not list Production orders to process…!!![*-)]
You need shop floor control - II for job registration. Refer Ax 2009 Quick Reference guide for more help…( which is available in this site for download)
Go to SFC - Setup - Terminals - Configure Registration Forms. It depends what you have in here - how many options are there? Anyway there will be one with the “promot for production area” selected as you are seeing this screen. Then you will see a field called “start page” on the overview and the general tab. I guess this is set to “None” set it to “Jobs”. This is the whole configuration of the screen you pasted into the post.
