No Dimension Value within the filter
I have encountered an error message when I run the Navision.
"No Dimension Value within the filter
Filters: Code: 000, GL Dimension No: 2"
Have everyone seen this message before and how to fix it?
Thanks.
One possibility is you have defined a filter that is no longer possible, and this is held in the zup file causing the issue, delete the zup file to see if it resolves it, if not we would appreciate more information regarding the version, is it upon opening, and if so how far do you get etc etc.
