Hello,
I upgraded to the Microsoft Dynamics NAV ODBC Driver v6.0.32964.00 and got the following strange behaviour. Lets say I want to select an entry from a table. If I use something like this and the entry with the name ‘Meier & Sohn’ exists
SELECT Nr_,Name FROM Kreditor WHERE Gesperrt=0 and Name LIKE 'Meier & Sohn’
a result will be returned. However, if I change the statement to:
SELECT Nr_,Name FROM Kreditor WHERE Gesperrt=0 and Name='Meier & Sohn’
NO RESULT will be returned.
this only happens, if the field contains an ampersand “&”.
everything worked fine before the update
the 2nd statement works fine in Oracle and MS SQL server using different tools (and it really SHOULD work anyway)
the problem can be reproduced using different clients (MS Excel, MS Access, Lotus Notes R7.03 and R8.53, Squirrel SQL Client)
Some background:
we updated the Navision server to v6, but kept the database at v5. According to our Navision support partner this approach is fine.
database will be upgraded in a while, so (hopefully) this might be a temporary thing
Questions:
did that happen to you before?
could/can you solve the problem or can you give any hints on what is going on here and where to look for a solution
Any help is appreciated, thanks in advance,
Th.
