Any bad experience with this combination? I have an e-shop solution built on ExpandIt modules that will not connect to Navision. The same installation works on NT4.0.
Still without connection or did you solve the problem ? Let us know.
Replace the mfc42.dll and msvcrt.dll in the CFRONT folder. Navision’s installation program installs the wrong version of these dlls. Copy these dlls from system32 folder. It should connect after that …
