I don’t understand. Many peoples tells what NF 2.60c(d) works fine with SQL2000. But i can’t!!! NF tells “ANSI or OEM code page on your computer does not match the 1257 code page on the server”!! It’s very funny and stupid message because i have Win2000Pro with code page 1257 installed. Some peoples tells about OEMCP in registry, another - about some fixes (updated STX file, for example). Where is truth? Attain works fine, but NF2.6 not. Business Applications Programmer Sertified Navision Developer SIA “Sintegra” Latvia
Hi, Problem is that your SQL server use another code page (no matter witch use Win2000). On install SQL use must choose collation code page 1257. Attain use SQL unicode. RGDS Gedas
Yes, i found my problem. SQL2000 must be installed in compatibility mode (without new “collation” feature). This is only for NF2.6. But Attain wotks fine with new SQLServer features. Thanks for reply. Business Applications Programmer Sertified Navision Developer SIA “Sintegra” Latvia
