NF 3.0 (User Portal)
Does anybody know if we will be able to call Codeunits and run Table triggers (OnInsert, OnModify,OnDelete,OnRename) and VALIDATE fields from the web front end ? tarek_demiati@ureach.com
Yes, i think so. The dataport will have some new futures, the first is that you can Import/Export data in XML format. And you can indent Dataitem. (Have relation like in reports.) You have a new propert for executing VALIDATE on imported field. You will also have a new function in CU 1 with ID 50000 where you coukd put your own code for call Codeunits. I don’t know if it’s possible to callTabel triggers. (But I hope so :wink:
