NextControl
Hello! I “installed” NextControl option in one of the forms so i could easily move between TextFields with Tab. The whole thing works fine however when i tried going backward (Shift+Tab) it didn’t go back the same way or it didn’t go back at all. Can this be fixed or set somehow?? lp prosen
Post product / version are we talking about? I’ve always found that if you changed the next control, the ‘new’ next control would Shift Tab back to the control it use to be next control to?!?!?!? Does that make sense? [:0]
We’re using Navision Attain 3.10a I’m not sure what you ment in your answer so i’ll try to explain my problem: On a form you can use Tab to move from one TextField to another. To witch field you’ll be moved next you specify in the NextControl option. So when using Tab you’re moving forward from one field to another (next one) but when you use Shift+Tab you should move from current field to the previous one but this backwarding doesn’t seems to be working properly… lp prosen
Prosen I did understand what you meant. I meant that even if you changed the next control property, the backwarding would still work the way it use to. However, after testing in 3.60, the backwarding does seem to act oddly!
Report it to your Solution Center so they can report it to Navision Slovenia. They will report this to Denmark. And maybe it will be fixed in next releases. If this bug is fixed, create a new signature for this forum with the text : lp prosen “The guy who got the NextControl-alt-tab bug fixed!”
Thanks guys for the tips. I’ll report this bug… maybe even change my signature :)) lp prosen
hi i too faced this problem. but was not sure that this is a BUG. So i did not reported. Hope this will be rectifed in next release.[:D] Harikesh
