NewPage on Demand
Dear all,
I want to print 3 records per page in a Report. Suppose there are 7 lines to print then it should print First 3 lines on 1st Page and Next 3 lines on 2nd Page and so on…
How can I do this ? Kindly reply ?
Have you tried playing with the function currreport.NEWPAGE?
Where I have to try and in which Circum.[:$]
1st Page in the Report
Item No. ITEM0001 ITEM0023 ITEM0026 ITEM0015
Description R.T.D. OCVBN U.P.T. OUTN " "
Quantity 1 1 " "
UoM PCS Kg " "
Unit Price 100 100 " "
VAT % 4 4 " "
Amount 104 1004 "
Variant RED0001 WH001 BL0001 N0001
Dim1 SL001 DF001 DF002 DF002
Dim2 RT001 UI001 TH002 UY002
2nd page
Item No. ITEM0011 ITEM0123 ITEM0126
Description N.S. U.P.A. OUTN "
Quantity 1 1 "
UoM PCS Kg "
VAT % 4 4 "
Amount 104 1004 "
You’re going to have cycle through and store the data in an array - then represent the array data on an Integer DataItem’s section below it.
Lavin
I have solved it. Thanks to all.
