Newly Created JournalNameId is not coming in Ax lookup of User system...
1.I created a new Journal Name in table field LedgerJournalName.JournalName as INV2012 in my server.
2.It is not present in Lookup for a User(User System).
3.I reset the Usage Data,and still the problem exists.
you are most welcome to help me in this case.
thanks in advance.
Thanks &Regards,
Britto John Baskar.A
Hi
Have you specify the JournalType while creating journal name? if you does not specify the journalType then it wont show the created journal name in the lookup…
If you specify the ‘journalType’ then check the user rights for the user system whether user has rights to access that journal name…
