We are installing Axapta 3.0, and the address field is a single field incorporating line breaks within the field between each address line. When preparing data within Excel, is there a char(13) or char(10) character we can insert that Axapta will interpret as the correct newline character?
When you prepare the data in Excel you could put every “adress-line” into separate cells. Then in the import-class you could manually merge theese cells…?
